usmcss
Feb 01, 2016Aspirant
Wn2000RPG XBOX ONE STATIC IP
Hey guys, I have connected the wn2000rpt to a cable modem/router SBG6580. I am using the wn2000 with an Xbox. It works with it both wired and wireless. The problem I am having is with the NAT on the X...
usmcss
Feb 03, 2016Aspirant
Ok maybe I had to many questions. Will the WN2000 let me setup port forwarding and static ip's on it or on my router to do it?
Thank you!
Thank you!
netwrks
Feb 05, 2016Master
Set it up as a Access Point - http://www.downloads.netgear.com/files/GDC/WN2000RPTV3/WN2000RPTv3_UM_19Oct2015.pdf - Page 14.
Your xbox has two MAC address, one for wired, one for wireless. you can reserve an ip addresses, per MAC address. All port forwarding shoud be done on your Router (if it supports it).
