Robsgear's avatar
Robsgear
WN2000RPTv3 firmware for Windows 10
Hi all,
Having been away from home for some time, when I try to connect my Netgear WN2000RPTv3 to my PC running on Windows 10 I get a message saying it is not compatible with Windows 10.
On further research I find (I think) that I have to upgrade the Firmware, however when I download the firmware and try to open the file I get a message "The disc image is corrupted".
Can anyone help with downloading and installing the firmware update please?
Thanks
Rob
    • Robsgear's avatar
      Robsgear
      Hi,
      Thanks for your reply. Unfortunately, as I said in my initial post, whenever I download the link and then try to open it I get a message telling me that the disc image file is corrupted.
      Regards
      Rob
      • TheEther's avatar
        TheEther
        Guru
        You are only supposed to unzip the zip file and image file within to the WN2000RPT.  You are not supposed to open the image file.
