techsupportsuck's avatar
Aug 02, 2016
wn2500 extender wont sync to d2200d dsl router
my new n600 wn2500 extender wont sync up with d2200d dsl router
  • DarrenM's avatar
    Aug 04, 2016
    Hello Techsupportsuck
    Have you tried to connect the extender with both methods with WPS or by going through the wifi setup? Try to factory reset the extender. Also make sure your main router is set to WPA2 security and also try to change the wireless channel.
    DarrenM
