shadysprings
Sep 09, 2012Aspirant
WN2500RP - Pot forwarding?
I've been using a WNDR3700 with a few cameras. I use port forwarding to get to each camera remotely. I just added a WN2500RP extender. Can I connect cameras to extender? and do I need to re-e...
shadysprings
jmizoguchi wrote: whatever the IP that camera needs to be reached is not different than before.
use the IP that you can view on LAN to the camera and forwarded
Thanks. So I would connect cameras to new SSID of the extender, and everything else stays the same I believe. The camera IP addresses are fixed and stay the same, the router still forwards the respective port to each cameras IP address now through the extender.
Think I got that right. Maybe I'm over thinking this.
