deone's avatar
deone
WN2500RP acts up every few days
I have a WNDR3400 netgear router connected to comcast business class using static IP. I have a WN2500RP that uses fast lane technology to connect to my router on the 2.4G band and devices connect to the extender on the 5G band.
Most of the time this works fine. But every few days devices cannot connect to the extender anymore. Rebooting the extender makes no difference. But rebooting the main router and then rebooting the extender fixes the problem.
When this problem happens, the main router seems to be working fine: i.e., I can connect other devices wirelessly to the main router; it is just the extender that seems to be in a bad state.
The 2.4G light on the extender is green always which I guess means that it is getting a good signal from the main router.
Any help debugging this would be much appreciated.
  • if you are using 192.168.1.x/ 255.255.255.0 then ALL network behind the extender will get 192.168.1.x ip
