Offthemap
May 09, 2012Follower
WN2500RP all lights green. iPad & iPhone will not make connection
Hi. Tried setting up several times strictly following instructions. Everything seems to set up ok. I can see the networks on the iPad. When I try to connect though it just keeps trying and trying w...
ggift_1029
May 27, 2012Tutor
Do you know if you have enabled any mac filtering on your verizon routers? If you do, no matter how you connect a device, it will not connect wirelessly.
HAve you tried connecting a device wired directly to the extender? Does it work or no?
