Offthemap
May 09, 2012Follower
WN2500RP all lights green. iPad & iPhone will not make connection
Hi. Tried setting up several times strictly following instructions. Everything seems to set up ok. I can see the networks on the iPad. When I try to connect though it just keeps trying and trying w...
jmizoguchi
May 27, 2012Virtuoso
ggift_1029 wrote: Do you know if you have enabled any mac filtering on your verizon routers? If you do, no matter how you connect a device, it will not connect wirelessly.
if one had used wireless access list (mac filtering) then you have to add it's wifi mac address on router side so "it will not connect wirelessly" maybe not a phrase to use.
