Offthemap
May 09, 2012Follower
WN2500RP all lights green. iPad & iPhone will not make connection
Hi. Tried setting up several times strictly following instructions. Everything seems to set up ok. I can see the networks on the iPad. When I try to connect though it just keeps trying and trying w...
jmizoguchi
May 27, 2012Virtuoso
Most your extender will hate to use WEP and also hackable so do not use WEP
if you use no encryption that should at least work but for all the extender important part of main setup is use PC wired to the extender and make sure extender and router is connected fine. Test with PC while connected to the extender and see if you can get on the internet.
all the extender will have "_ext" ,2nd SSID broadcast from the device. While pc are still using ethernet to the extender setup the 2nd SSID and continue to adjust the setting to find the best combination
