mavigneri's avatar
mavigneri
Follower
Apr 21, 2012
WN2500RP compatibility
I currently use Uverse for my home wireless needs. Can anyone tell me if the WN2500RP will be compatible with AT & T 2Wire device?
  • Yes it is compatible with any wireless router / Access Point, that why it is called "Universal" wifi range extender...:cool:
  • Yes , generally speaking ... always expect unexpected compatibility but as long you have WPA ,WPA2 encryption used on main wireless router like that it will JOIN the existing wireless network
