Roellll's avatar
Roellll
Follower
Jan 08, 2017
WN2500RP disabled WPS, not able to install anymore
Hi,
Few years ago i installed my WN2500RP successfully. Since i didn't want to see the WIFI signal coming from WN2500RP i disabled WSP.
Now i would like install WN2500RP somewhere else, however i encounter the problem that i'm not able to install anymore.
WSP install doesn't work since WPS disabled.
Manual install via www.mywifiext.net does also not work, since i'm not able to connect the wifi 2500rp (doesn't show up since WPS disabled)
I already tried fabric reset, however WPS still does not show. Have i destroyed my wn2500RP by diabling WPS (and removing all connected devices), or does anyone know a solution for this problem?
Kind regards,
Roel
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Roellll
    You should be able to hold the reset button down for 10+ seconds to get it back to default settings.
    DarrenM
