bngilbert
Sep 22, 2013Aspirant
WN2500RP drops router / forces router offline
I have recently purchased a WN2500RP. After some time I was able to get the extender to connect to my router, xfinity SMCD3GNV. I have internet access on multiple devices for about 5 mins, then I lo...
mothball
Nov 02, 2013Aspirant
I am having the same problem - i purchased the WN2500 originally to deal with poor usb performance by Win 8 (constant usb failures that microsoft new about but was reluctant to fix). the wn2500rp worked like a charm until last week when it began losing/dropping the wireless connection to the router. i have a desktop and a blu ray hardwired to the wn2500rp and i am using it as a shared remote wireless adapter. i have tried reconfiguration and resetting and nothing i only get netgear_ext and it will not connect to the network.
From the status of the front panel led's i believe the radio portion of the unit has failed (no signal icons present). i am going to check my warranty time
