vertol
Oct 24, 2016Follower
WN2500RP Extending via ports
Hi,
Hi have 2 WN2500RP extenders for each end of my home with a WNDR3400V2 Dual band router.
I have had so so success with wifi extending with for whatever reaon, the connections to the router dropping out....
So my question is this...
I have wired lan to where the extenders are located, is there a way to use the 10/100 cables to connect to the extenders and then there would obiouly be a super solid connectiont to the extenders.
and then the obvious next question is how do I set it up...
thanks
vertol
1 Reply
Yes, what you want to do is set them up in Access Point mode. Follow the instructions on page 16 of the manual.
