D2K1
Feb 20, 2016Aspirant
WN2500RP Resets itself
As the title implies, my Wifi Extender randomly resets/restarts itself.
So far it occurred three times, but not in a pattern.
However when that happens I can't connect to the Extender (Using a Device) because of "Authentication Problem"
This is becoming very annoying because it happens when you least expect it...
Is there any possibility that someone is pushing the factory reset button or logging in and erasing the settings? Try changing the admin password to eliminate the latter.
- D2K1AspirantI'll change it, however no one has touch the extender but Extender Network is secured with a password. [WPA/ WPA2 PSK]
If it's possible that someone can get access into network & the Extender then that's a problem
