bdwarren001
Oct 06, 2014Follower
WN2500RP sees my network but will not connect
My new WN2500RP extender sees my network on the "mywifiext.net". However, when I put in my passphrase I get this: The Extender was not able to connect to your existing network. If you entered th...
storm_2003
Oct 24, 2014Novice
Hi bdwarren001,
Kindly check what type of security type of your router if it is WPA. If it is I suggest you use higher security like WPA2-PSK(AES). You can still use the same passphrase though then reconnect the extender by going back to mywifiext.net.
Let me know if this works.
