bdwarren001
Oct 06, 2014Follower
WN2500RP sees my network but will not connect
My new WN2500RP extender sees my network on the "mywifiext.net". However, when I put in my passphrase I get this: The Extender was not able to connect to your existing network. If you entered th...
storm_2003
Nov 03, 2014Novice
@Nightknight92 - Do you also have MAC ACL?
If yes kindly turn off ACL first then let the extender connect. Once connected you can then add the MAC address of the extender and re-enable the ACL.
If no, what is the exact error when you connect the extender to your router?
