bdwarren001
Oct 06, 2014Follower
WN2500RP sees my network but will not connect
My new WN2500RP extender sees my network on the "mywifiext.net". However, when I put in my passphrase I get this: The Extender was not able to connect to your existing network. If you entered th...
Nightknight92
Nov 04, 2014Aspirant
No I have the MAC Filter set in forward mode. I can provide additional information if needed. I also tried to reset to default both devices, to upgrade firmwares, even set every wireless protocol possible (tried 802.11b, b/g, b/g/n, only n in both 20Mhz and 20/40Mhz.
It still gives me the same error:
It's not working even through WPS push button.
If you entered the correct passphrase, and the Extender did not connect to your existing wireless network, you might need to move the Extender closer to your router or to a position with a better line of sight. Check the Extender LEDs to isolate the problem. The LEDs are explained in the installation guide and user manual for your product.
If you have Access Control List (ACL) enabled in your router, please make sure you have added below MAC address into your router's Access Control List (ACL).
