makinworks's avatar
makinworks
Wn2500rp slower bandwith than WNR2000v4 Router
I do speed test from the Wn2500rp and it is half the speed of when connecting to the main wnr2000v4 router...is this correct? or am I not setting the Repeater (WN2500rp)correctly?
Please help let me know before I try fixing something that is not possible?
I use NETGEAR GENIE on the iphone to access both networks...but obviously that genie doesn't really work on the REPEATER......or doesn't allow me to make setting changes...
I am hooking up to the Router via laptop and can see everything.
But have not hooked up to the RP unit....am I able to access that unit just like this router?
Thanks for any help I think this group is great at solving problems...
thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello makinworks
    When you use a wireless extender you are going to have speed loss up to 50% you may want to adjust the wireless channel in the wifi settings of the router to try and improve the wireless speed on the extender.
    DarrenM
