kris245's avatar
kris245
Follower
Oct 19, 2018
WN3000 cannot connect
My WN3000 wifi extender cannot connect to my wifi. Even though I have gone through the setup process several times, the wifi extender show up with my network name and the _EXT at the end. No matter what I do it cannot connect and the wifi lamp newer lights up.
I use windows 10.
The wifi extender was located directly next to the router.
  • StephenB's avatar
    Did you try
    • resetting the extender
    • connecting a client to the NETGEAR_EXT network
    • browse to www.mywifiext.net
    • set up the extender from the web ui
    Don't press the WPS button.
  • Same issue here w AC1200 EX6150 v2
    Worked fine for 4 months. Now will "not connect to Internet".
    I have followed EVERY recommendation at Netgear online.
    My router can see the extender. It shows 2 green lights on lower right front.
    Will not connect to Internet.
    Tech Support tried to extort money from me due to "after 90-days free warranty period." Are you kidding?
    How do I get Internet connection back to this device?
    Thank you.
