CHUCK12351
Jun 25, 2016Aspirant
WN3000 V2 FIRMWARE CORRUPTED ALL .CHK FILES NOT .IMG
V3 DOWNLOADS AN IMG FILE BUT V2 DOESNT. ALL FIRWARE VERSIONS.THE UPDATE WILL NOT TAKE A CHK FILE OR A FILE RENAMED TO IMG.
- Jul 06, 2016
well looks like the server web site is working now .
There are 2 web sites to get the new firmware? http://downloadcenter.netgear.com/ with the drill down
This gives Firmware Version 1.0.0.36 which is an IMG file and it loaded! server now says 1.0.0.36 is the latest.firmware
The other is http://www.netgear.com/support/product/WN3000RPv2 This site gives a newer version but its WN3000RP-V1.0.2.64_1.1.86.chk
Its a chk file.The release note even says its a chk file.
But http://www.mywifiext.net. won't accept it. Popup says " Please assign the correct file.The file format is "*.img""
Changed it to .img. No GO .
Please fix this site.
You need to fix this
DarrenM
Jun 27, 2016Sr. NETGEAR Moderator
Hello Chuck12351
Can you be more clear on the process you did when trying to update the firmware so I can look into this issue.
DarrenM
CHUCK12351
Jul 03, 2016Aspirant
2016-07-03 05:20 AM
Logged on to the Netgear server using . Clinked on firmware upgrade.
- http://www.mywifiext.net.
- Clinked on firmware upgrade
- Clicked Maintenance > Firmware Upgrade
Sever did not respond
Went to the Netgear web page support area clicked on the N 3000 . version 3 came up. Downloaded the version 3 by mistake. The zip file contain an image file. When back to the server and try to upgrade.. upgrade said it was the wrong version.
Went back to the support page and scrolled down to version 2.
Downloaded all versions of firmware. all including the latest WN3000RP_V1.0.2.64_1.1.86.zip .
The zip files contained check files not image files. The upgrade button would take none of them.
- DarrenMJul 05, 2016Sr. NETGEAR Moderator
Hello Chuck12351
Have you unzipped the .CHK file before trying to load it onto the extender? IS your router connected to the internet may be unable to reach our server. Have you tried to use a different web browser? you may also want to do a factory reset and then try to upload the new firmware and do the setup again.
DarrenM
- CHUCK12351Jul 06, 2016Aspirant
