AndyOxon's avatar
Oct 24, 2016
WN3000RP-200UKS causes seemingly odd behaviour with WNDR4500 v2
There appears to be an issue connecting Netgear’s WN300RP WiFi Extender to NetGear’s WNDR4500 Wireless Router. If WPS is used to pair the devices, then SSIDs, Passphrases, and IP addresses (and maybe more) appear to get scrambled in the router. If, however I setup the Extender manually via the web-interface, then the extender appears to work for a limited time before it somehow causes the Router to lose LAN IP allocation information and the network must be rebooted.
Does anyone have any ideas about what’s happening, or how to setup a seamless pairing of the two devices?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello AndyOxon
    Do you have some type of modem/router combo that the WNDR4500 is connected it?
    DarrenM
    • AndyOxon's avatar
      AndyOxon
      Guide
      Thanks for replying Darren. Of course, the latest Virginmedia Modem/Router (in Modem mode) is installed on WAN. And, both WN300RP & WNDR4500 have up-to-date firmware.
      • DarrenM's avatar
        DarrenM
        Hello AndyOxon
        I would double check the modems settings to make sure DHCP is disabled on it.
        DarrenM
