lodeon
Jun 30, 2011Novice
WN3000RP disconnects
Just picked up my wn3000rp and hooked it up to my d-link dir-855 main router.
All my wireless clients can connect to the extended network without any problems but... after 10 minutes the connection is dropped between the router and the wn3000rp.
I have tried to restore it to factory defaults and reconnect it. Same thing happens every time.
MAC filtering is turned off on both ends.
Any ideas would be helpful. Thank you.
Nicklas
Nicklas
- herny66Novice
- JJS68Tutor
herny66 wrote: New firmware v. 1.0.1.18 :p
http://support.netgear.com/app/answers/detail/a_id/20013
been using it for a couple days now, works great so far - JJS68Tutorstill running good, this new firmware did the trick
- Shick31AspirantOk will give that a go - I assume I can add further MAC addresses in the future?
