JUGONE
May 21, 2012Follower
WN3000RP does not connect Internet
I have a WN3000RP. I want connect to a Wireless Router 3Com OfficeConnect (WPA2) and extend the signal. 3Com is wired connected with another router Linksys connected to my ISP. So the schema is ISP -...
ggift_1029
May 21, 2012Tutor
It might have not installed the extender properly. Try to hard reset it. You would know if it successfully resets it, Only the status light will lit green.
After reset:
1. HAve your extender and laptop on the same room where you have the router
2. On the laptop, scan for networks
3. Connect to NETGEAR_EXT, it's unsecured so you should be able to connect without any problem
4. Open a web broswer like Internet Explorer
5. It should redirect you to NETGEAR Smart Wizard. If not type http://www.mywifiext.net on the address bar.
After reset:
