CarrotCake
Apr 30, 2022Aspirant
WN3000RP Extender Password Issue
Model: WN3000RP
Firmware: V1.0.2.64_1.1.86
I initially set up the extender and connecting to the router wasn't an issue. But when I went to enter the password (that should be the same as my routers password) it did not work. I have reset the extender, changed the passphrase and even restarted my router and then the extender and still no luck. We also erased the extender on Netgear Genie and then reconnected it to the wifi. This extender was used in a previous home with a different router but I'm unsure if that could be a reason why.
are you connecting it to the router using wps?
if so, factory reset the extender again (push and hold reset for 7-15 seconds while powered on), then install it using the installation assistant.- CarrotCakeAspirant
Hello plemans ,
Thank you for the response. Yes we attempted to use WPS and just tried to use the installer assistant. The netgear page that pops up didn't load but we were still able to access the installer assistant and connect to the router. When we enter the passphrase it says our network requires a WPA2 password. I attempted to go to the mywifi internet page while on the extender but it wasn't working. Would I need a PC for this process?
It can sometimes be easier/smoother on a pc/laptop.
What route are you connecting it to?
Are you using wpa2 on the router?
