jormalaaksonen's avatar
Nov 02, 2015
WN3000RP fails to establish wired connection
Hello!   I have a WN3000RPv1h2 with V1.0.2.64_1.1.86.  It's working fine as a WiFi extender and used to work also as a wired access point.  Now, however, the wired connection cannot be established ...
  • jormalaaksonen's avatar
    Nov 03, 2015
    Hello!
    Thank you nhann for your rapid answer.  It really helped and I'm now happily using also the wired conncetion.
    Thanks!
    Jorma
