jormalaaksonen
Nov 02, 2015Aspirant
WN3000RP fails to establish wired connection
Hello! I have a WN3000RPv1h2 with V1.0.2.64_1.1.86. It's working fine as a WiFi extender and used to work also as a wired access point. Now, however, the wired connection cannot be established ...
- Nov 03, 2015
Hello!
Thank you nhann for your rapid answer. It really helped and I'm now happily using also the wired conncetion.
Thanks!
Jorma
nhann
Nov 03, 2015NETGEAR Employee Retired
Hi jormalaaksonen,
Did you start experiencing this issue after a recent firmware upgrade to 1.0.2.64?
If you have not already, you can reset the WN3000RP to factory defaults:
You can press and hold the Factory Settings button on the side panel for 7 seconds. The Extender resets, and returns to its factory settings.
It sounds like it could be a hardware issue, you can check with support for other solutions and see if you are under hardware warranty.
jormalaaksonen
Nov 03, 2015Aspirant
Hello!
Thanks!
Jorma
