Hptom14's avatar
Hptom14
WN3000RP install challenges
Trying to install extended to c3000 Netgear router. Can’t get it to work. I can connect client to extender no problem. I can connect extender to router no problem. Just can’t do both at the same time. Support has been on the phone with me for 2 hours with no luck. What could be wrong ?
  • StephenB's avatar
    Are you wanting to set it up in AP mode or extender mode?
    Have you tried setting it up without using WPS?
    • Hptom14's avatar
      Hptom14
      Yes i have tried setting it up without wps and i am using it as an extender vs as an access point.
      • StephenB's avatar
        Does it work over ethernet after you complete the setup?  Or does that fail also?
        Is this a new purchase?
