Mekawi44's avatar
Mekawi44
WN3000RP Installation using co-axial Cable
My router N900 router is installed in my basement. Signal is too weak to cover the second floor thus I need to install the range extender on the second floor. Placing the extender on the first floor ...
  • Mekawi44's avatar
    Sep 18, 2016
    Wireless AP is working ok. Not confident yet if my understanding of v3 is correct or accurate.
