pdneri's avatar
pdneri
Follower
Aug 06, 2016
WN3000RP replace antenna
Is it possible to remove the receiving antenna (the one connected to the router) and replace it with a cable and a new antenna (or keep the original one)?
I need to put one of the 2 antennas ouside the window
1 Reply
  • Como puedo colocar otra compañìa de cable que estoy utilizando ya que cambie la anterior
