Kangarooo's avatar
Kangarooo
Follower
Aug 14, 2023
wn3000rp v1 Cant log in- website cant access, reset doesnt work, cant go to maintenance to update
https://www.netgear.com/support/product/wn3000rp
http://192.168.1.250/ can open can choose language, then for second it shows next screen to choose network type and it opens https://mywifiext .net/  that doesnt connect
On repeater theres only one light showing green
Tried 3 times reset 10 and 15 seconds
How to do some deep reset that will give update screen, or tell me link to maintenance update screen link so i can open it with http://192.168.1.250/ update or something like that
Tried connecting with WPS to router and it worked- it made Wifiname_EXT but password doesnt work the same and still cant open https://my wifiext .net/
No RepliesBe the first to reply
