Omuro's avatar
Omuro
WN3000RP will not connect to mywifiext.net
I purchase the WN3000RP wifi extender and the initial connection setup happen without problems, I used the existing network name as well the password everything seemed OK but when I verify at my wifiedT.net it says "you are not connected to your wifi extender network" please help! Thank You
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    That message (which is Internet based) usually means that whatever device you are using to attempt to access the extender admin pages, is currently wirelessly associated with another access point (typically the base station).
    • Omuro's avatar
      Omuro
      Babylon5; thank you for your input in my dilemma-solving efforts, I know that you want to help me and I will say to begin that I didn't understand what it means "base" after I connected the range extender into the wall electrical outlet and connected it (two green lights came on) as I understand one is the extender is connected to the router and the other one you are connected to your device, then that means I'm connected also my smart tvs Netflix doesn't buffer anymore but the mywifiext.net says "you are not connected to your extender network" please help me understand what is in reality going on (please forgive my ignorance, I a computer illiterate) thank you! HAPPY NEW YEAR!
    • Omuro's avatar
      Omuro
      ... Will I need to update the firmware? Just thinking!
      • Babylon5's avatar
        Babylon5
        The ‘Base Station’ is a common name for the device that the wireless extender connects to, typically this will be a wireless router as in your case.
        The URL www.mywifiext.net will be intercepted by the extender and provide log-in to the extender admin pages, but this will only work if the computer is connected to the extender.
        If the computer is not connected to the extender, most likely it is connected to the base station (router), then the router will pass on the URL request, and you will see that Internet based web page that you described.
        So, to make use of the www.mywifiext.net first make sure that your wireless device is connected to the extender wireless and not the router wireless.
