joedelaneycalp
May 04, 2020Aspirant
WN3000rpV.3
trying to connect this extender to fritzbox router. have reset it many times but router is not showing the extender. Any ideas?
are you setting up via wps or via the installation wizard?
Which fritzbox?
What firmware is on the extender?
- joedelaneycalpAspirant
Thanks for reply
Trying to connect via WPS
Fritz is 7650
Cannot find firmware version on extender - any ideas where/how todo this?
When I try to access upgrade to firmware on this link I cannot access file
https://www.netgear.com/support/product/WN3000RPV3.aspx#docs
Sorry Fritz 7560
