TheIronWolf
Jan 20, 2016Aspirant
WN3000RPv2 extended network very slow download speed
I am having issue with WN3000RPv2 extended network. I am able to successfully configure it to extend my wireless network. However, internet connections going through extended network are extremely sl...
- Jan 31, 2016
I decided to move to another router and problems went away. Thank you for your help Andy.
TheIronWolf
Jan 27, 2016Aspirant
Yes, “Desktop 2 to any machine via primary SSID or secondary SSID: ~700k downloadd/upload” is the problematic system.
"You mention a ‘network cable to the extender’ for Desktop 2, does this also give poor Internet throughput? " - yes, I get 5mb/s in LAN via extender connected to base router and ethernet cable to Desktop 2. But, Internet connection is unusable. Very slow, and unreliable.
"Is the Primary SSID the base router and the Secondary SSID the extender?" - yes, this is correct.
Router is: NETGEAR WNR3500Lv2 firmware V1.2.0.34_40.0.75
Modem is: MODEL: Arris WBM760A
| Firmware Name: | TS0706116_121614_WBM760_CM820 |
| Firmware Build Time: | Tue Dec 16 06:47:09 EST 2014 |
Thanks for bearing with me.
TheIronWolf
Jan 31, 2016Aspirant
