cajunpen
Apr 08, 2015Novice
WN3000RPv2 Range Entender
I have been using the WN 3000RP Extender for several months now. I have ATT Uverse for my Internet provider. My ATT Modem recently died and I had to replace it.
Now everything is working great again EXCEPT now the WN3000 is still hooked up to my old modem. I can't figure out how to reset it so that it links up with the new modem. I've tried pressing the "Factory Reset" button, but this does nothing.
Any advice will be greatly appreciated.
Bill
1 Reply
- storm1985Prodigy
1. Connect to existing WN3000RPv2 SSID.
2. Access mywifiext.net.
3. Under Setup click on Connect to Existing Network.
4. Select the new SSID of the new modem/router.
5. You can also change the SSID of the extender.
6. Once changed go to your computer's WiFi connections and connect to the new SSID on step5.
