apronedsamurai
Aug 15, 2018Aspirant
wn3000RPv3 keeps disconnecting and taking rest of internet with it?
"The network gateway is accessible, but Windows couldn’t receive network traffic from the Internet."
This is the message I keep getting and my internet keeps cutting out.
I have Windows 10 an...
apronedsamurai
Aug 16, 2018Aspirant
Ok.
So I did what you said, power cycled the router and left the Extender on.
No change at all, the internet was still inaccessible. When I pinged 8.8.8.8 and google, no luck with either.
The weird thing...I was unable to access either the Router OR the Wifi Extender ip addresses!
apronedsamurai
Hi,
Did what you said tried to access internet via the PS4 with the Ethernet cable disconnected from the PC, unable to get/form connection.
- apronedsamuraiAug 16, 2018Aspirant
Have also tried a different Wifi Extender model....getting exactly same issue :(
- StephenBAug 17, 2018Guru - Experienced User
Which says it's not the extender, it has to be something else. I'm thinking the PC is the most likely cause. Did you try running the malware scan on the PC?
- apronedsamuraiAug 17, 2018Aspirant
Yes I did, some issues were detected, I removed them all, ran several other scans after that, still the issue persists...
I have reinstalled Windows 10.
Hopefully that helps...
I have reinstalled Windows 10. ... Hopefully that helps...
I hope so too.
