wilson970423's avatar
wilson970423
Follower
Mar 19, 2016
WN3000RPv3 sucessfully connect to the router but the wifi logo shows "no internet"
Same as the topic...
router using is cisco, model no. WAG54G2
when connected, all 4 lights on extender on, but no internet access (both my windiw 10 notebook and android phone).
any possible reasons causing the problem?
THX for HELP
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello wildon970423
    I would try to factory reset the extender and then do the setup again and see if it will connect to the internet. also make sure the SSID is not exactly the same as your main routers SSID.
    DarrenM
