John_Wick_Jr
Jul 05, 2017Aspirant
WN3000RPv3 when configured, grants me no internet access
With my wifi extender, I reset the it to its factory default twice and upon configuration, it still does not give me internet access when configure (all lights would be on and green) Update #1: a...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello John WIck Jr
Have you tried both methods to connect it to the router WPS and manual setup? Are you using WPA2 security on the router?
DarrenM
John_Wick_Jr
Jul 08, 2017Aspirant
Yes sir, I have tried both methods. The security is WPA.
I would appreciate it if you could walk me through a set up, so that I could find out if there was something that i did that was wrong.
- DarrenMJul 11, 2017Sr. NETGEAR Moderator
Hello John
This KB has all the setup methods.
https://kb.netgear.com/23517/Setting-up-NETGEAR-Wi-Fi-Range-Extenders
DarrenM
- John_Wick_JrJul 15, 2017Aspirant
I checked out and tried the steps again according the to the page. 1 thing to note: the smart genie set up tool has a different look/interface from the "smart genie" used when configuring the extender.
Upon going set by step, upon completion I still have the same dilemna: All the lights are green suggesting a great connection from router to extender and from extender to device, but the extender still doesnt grant me internet access.
