John_Wick_Jr
Jul 05, 2017Aspirant
WN3000RPv3 when configured, grants me no internet access
With my wifi extender, I reset the it to its factory default twice and upon configuration, it still does not give me internet access when configure (all lights would be on and green) Update #1: a...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello John WIck Jr
Have you tried both methods to connect it to the router WPS and manual setup? Are you using WPA2 security on the router?
DarrenM
rogert
Jul 26, 2017Aspirant
Hi
I have a similar problem with my WIFI extender although only when I turn on Access Control on the router (it is a Netgear CG3000v2 as supplied by Optus Australia). I have added the MAC address for the extender to the Access Control list in the router. All other devices connect OK with Access Control turned on. Without Access Control, the extender works OK.
The extender has firmware version V1.0.2.24. The router has V2.08.07. I'm running Windows 10 Home.
Cheers
Roger
