Nickf99's avatar
Nickf99
WN3500RP- Super slow speeds
I use the WN3500RP to game on my xbox one and whenever I run speed tests on the system it says my download speed is about 1mb or 2mb, but never dips above. Any tips/help would be much appreciated!
  • minions08 wrote:
    Check the firmware of the extender. It may need an update.
    Firmware is up to date, on both the extender and the router.
  • I'm thinking I may just invest in a powerline adapter and plug that directly into my router because I cannot figure this out.
  • minions08 wrote:
    Can you check the link rate you are getting on the extender's UI?
    I'm getting 105mbps link rate for the extender. Where is all this bandwidth going?
  • minions08 wrote:
    Connect a device wired to the extender and check the speed. Also try moving the extender closer to the router.
    I have connected the system with an Ethernet cord to check the speed and I get the same speed. I have not however moved the extender closer to the router.
  • Connect a device wired to the extender and check the speed. Also try moving the extender closer to the router.
  • Also, I have the Comcast Blast wifi plan, which is 105mbps. So with the extender I should atleast be getting 20mbps.
