TheCustomer's avatar
TheCustomer
WN3500RP was working, now it isn't: factory reset & reinstall didn't fix the problem
Yesterday I set up the range extender. it worked Android Phone & MacBook connect just fine   Today: no The devices can see the network, but password isn't accepted. As the same fault is on both...
