mahesham22
Jan 13, 2011Aspirant
WNAP102 and Blackberry Bold 9700 connection loses
Hi
we are using Netgear WNAP210 as an access point.
It works fine with all the devices except blackberry phones. I tried 3 different handsets of blackberry 9700 but with no luck.
Here is the Problem: my handsets connects to AP successfully. but as soon as I try to open any web page, it drops the connection and i can't even ping AP from blackberry. even I can't ping blackberyy IP from any pc on network. After a copule of minutes it connects again. But when any data transfer begins, it drops the connection.
I am using it in India. Set the region as India. Tried with 'bg' and 'gn' modes and also tried altering frequency but none of them worked.
Tried following security options:
WPA-PSK & WPA2-PSK (TKIP+AES),
WPA-PSK (TKIP)
WPA2-PSK (AES)
Any help will be very appreciated
Thanks
-Mahesh
- mahesham22AspirantModerators, Please edit the Product name from WNAP102 to WNAP210 in the title, it was a typing mistake.
- SatrasAspirantI had the same problem and couldn't get it to work.
I upgeaded and downgraded the firmware bt nothing helped. Then i started playing around in the WIFI menu and finally got it working. :D
Firmware: WNAP210_2.0.12
Wireless Mode:2.4GHz Band: 11ng
Turn Radio On: yes
Wireless Network Name (SSID): MYSSID
Broadcast Wireless Network Name (SSID): Yes
Channel / Frequency: Auto
MCS Index / Data Rate: Best
Channel Width: Dynamic 20/40 MHz
Guard Interval: Auto
Output Power: Full
Thats just my settings, but non of them really matter as I found. Some people said that setting the Channel to fixed 6 would help.. but not for me.
The only thing which worked for me was entering the QoS Menu and to disable WMM Powersave.
"Enable Wi-Fi Multimedia (WMM)" was still on.
Hope that helps.
