jrfoleyjr
Oct 29, 2013Aspirant
WNDR3400v2 Wireless security question.
Does Netgear make a router or firmware that allows to kick a wireless user? :confused:
If you have a pirate on your system regardless of having set the security, there should be a way to kick/ban that user without having to shut down the whole router. I have been over under around and through my settings and do not find a way to send a pirate packing. :eek:
- jmizoguchiVirtuoso
- ChrisP66NoviceFirst, I would recommend changing your password. Otherwise, on this router in the advanced setup>wps wizard> wireless setup, at the bottom there is a section to setup a "wireless card access list". That should let you whitelist the mac
addresses of your own equipment.
Good luck! - FransDeGreefNoviceThe technology concerned in business and residential security systems have created them safer and easier to use than ever before, however that doesn't continuously mean that newer is best.
One of the foremost vital advancements in business and residential security over the previous couple of decades has been the arrival of wireless technology. whereas alarms wont to be hard-wired to a centralized electrical device from everywhere a home or workplace, these days receivers will merely be placed where necessary, and that they can transmit and receive a proof from that box.
