jeffnickc
Apr 04, 2012Follower
www.mywifiext.net not working
Trying to upgrade firmware per included documentation in WN2500RP using www.mywifiext.net in order to access NETGEAR Genie to select "Firmware Update". Not able to (read: not tech-savvy enough) to up...
ggift_1029
May 15, 2012Tutor
Make sure you are connected to extender network (wired or wireless) before you can access the GUI. If www.mywifiext.net is not working, then try http://192.168.1.250
