mgeorge
May 20, 2017Guide
2.4GHZ Band not broadcasting
My Netgear is not broadcasting the SSID on the 2.4GHz range. It says its enabled but it no devices can see it. My 5 GHZ band is fine and working. I am on the latest firmware I think at V1.0.2.80. It ...
- May 22, 2017
Try to re-upload the latest firmware once again and then reset.
Once done, reconfigure the router and see if you can get it up and running again.
ElaineM
May 23, 2017NETGEAR Employee Retired
Thank you for the update.
Do not forget to mark the solution.
Have a great day!
mgeorge
Jun 19, 2017Guide
This issue has returned. For some reason the 2.4Ghz signal des not let anyone connect to it however the 5Ghz signal works fine. When I log inot the router everything shows green like it is wokring but it is not. To avoid any confusion it is happening on IOS and Windows devices.
Model WNDR4300|N750 V2.0
How would I attach the logs?
