naweenio's avatar
naweenio
Follower
Jul 13, 2022
AC1200 not able to reset and can't remember security questions
I cannot reset to factory using the reset button. Does anyone know of another way to do it? I need to check settings.
  • michaelkenward's avatar
    michaelkenward
    What happens when you try?
    What are you doing and what goes wrong?
    You can do this from the browser graphical user interface (GUI). But if you cannot get in your are stuck.
    Which Netgear device do you own?
    AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    Look at the label on the device for the model number.
  • plemans's avatar
    Are you pushing and holding reset for up to 30 seconds while powered on?
    what happens when you do this?
