Dennis_'s avatar
Dennis_
AC1750, Internet suddenly not working
I've had this router for about 2 years without any problems at all, but suddenly (when i just built my pc, no idea if this is related to the problem) the internet stopped working (internet light on the router is off). Sometimes when I restart the modem and router there is internet for about 10 minutes until it disconnects again (both through ethernet on my pc and wifi on my phone). I've tried everything I could find online, updated firmware and even reset the router a couple of times, but nothing seems to work. The ethernet cable works fine when plugged directly in my pc. What can I do to fix this problem?
  • Sorry for replying to this post months later, but I'd like to let you know that I finally fixed the problem by using an ethernet cable tool to fix the end of the cable. I didn't try this before because the cable worked as normal directly in my pc and on a networking switch i used since the router stopped working. I guess I was too rough getting it out one time
  • michaelkenward's avatar
    michaelkenward
    What is this modem?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    According to the manual, off means "No Ethernet cable is connected between the router and the modem."
    • Dennis_'s avatar
      Dennis_
      Thanks for your reply,
      Modem: zxhn h369a.
      Firmware version: V1.0.4.82_10.0.57
      The ethernet cable is definitely correctly connected to both the router and modem as the problem can be fixed sometimes for small time by just taking out the cables and restarting the modem and router.
        michaelkenward
        Modem: zxhn h369a.
        And the make is?
        Google suggests that this may be a modem/router.
        Does it have more than one LAN port? Does it also do wifi?
