JudeGlad
Jun 05, 2021Aspirant
AC791L Jetpack portforwarding error request timed out 25565 port
I have portforwarded 25565 and I have started my Minecraft server and it is listening on port 25565
[21:42:39 INFO]: Starting Minecraft server on *:25565
I have turned off my firewall i can't turn the firewall off on the router the option is not there
I ran canyouseeme and it says request timed out for port 25565 and i have no idea what's going on
can someone help me?
> I have portforwarded 25565 [...]
How, exactly?
> [...] and I have started my Minecraft server [...]
On what?
> [...] I have turned off my firewall [...]
_You_, personally, have a firewall? Or do you mean some firewall or
other on some gizmo or other, or what?> I ran canyouseeme [...]
Which is testing which IP address? And "yours" is?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
Hint: Usual problem number 1 in that list is number 1 for a reason.> Model: AirCard 791L|Verizon Jetpack 4G LTE Mobile Hotspot (AC791L)
- JudeGladAspirant
i went to 192.168.1.1 went to advanced and port forwarding and then entered 25565 as the port and entered my local ip hit save then restarted the aircard
I started my Minecraft server on a pc?
i turned off windows defender firewall
why do I have to give you my public IP address that is private
> [...] entered my local ip [...]
"my"? _You_, personally, have a local IP address? Or did you mean
the IP address of some computer or other on your LAN? Or what?> https://community.netgear.com/t5/x/x/m-p/1859106
Look for "How did you ensure [...]?".
Are you asking me or telling me? Its IP address?
You don't need to give me anything. It might be helpful if you
compared "the IP address of the WAN/Internet interface of your router"
with "what you're using as your public IP address from the outside
world".
> https://community.netgear.com/t5/x/x/m-p/1859106Did you look at it?
