usaditya's avatar
usaditya
Access control or MAC Filtering is not showing in R6300 v2 router configuration page.
Hi ,
I can't control access or filter MAC addresses by this router, i didn't find any option like this in configurtion utility page.
Can anyone please help me in finding that option in this router.
  • usaditya wrote:
    Hi,
    I've checked and tried every possibility to find that option , but no use till now i didn't find that option........
    You still can't find it?
    After logon, chose the "advanced" tab on the top.  Then "advanced setup" (which should be on the bottom left).  That will expand into several submenus.  Click on "wireless settings", and you should see the "setup access list button" described on page 99 of the manual.
    • usaditya's avatar
      usaditya
      Hi,
      • StephenB's avatar
        usaditya wrote:
        Hi,
