AlRom27's avatar
AlRom27
Follower
Sep 30, 2023
Adding a VPN
I'm a novice and I'm trying to add PIA VPN to my router. I can't seem to log into my router setting.
  • michaelkenward's avatar
    michaelkenward
    You may need to talk to the people who supply the VPN. (Is that PIA?)
    If it requires custom firmware on your (anonymous) router, Netgear won't support it.
    • plemans's avatar
      michaelkenward is correct. PIA requires compatible routers to install to as its 3rd party firmware. You'd have to check with them if its compatible.
