cssaus's avatar
cssaus
Attaching a Switch to a WNDR4500 Router
My WNDR4500 has all 4 LAN connections occupied. I would like to know if I can attach a Switch to one of the LAN ports in order to expand the number of connections.
Thank you.
Steve
  • > [...] I would like to know if I can attach a Switch to one of the LAN
    > ports [...]
       Yes (assuming that you have a switch and a cable).
    > ports [...]
  • A simple "yes' would have been preferred.
    That being a Gbit router, a Gbit switch would serve you better in the future.
    • antinode's avatar
      antinode
      Guru
         "preferred" by whom, you?  Who cares?
      > future.
         "would"?  Your confidence is impressive.  I'd say that it _might_,
      but that could depend on the devices to be connected to the switch.
      With my weak psychic powers, I can't determine that from the available
      information.  I have a few old printers and other "Fast" Ethernet
      devices which wouldn't care if they were connected to a gigabit switch
      or something slower.
