rungel
Jan 27, 2016Tutor
Avast says my WNDR3800 has NON-2015-0211 issue
Is this something i need to fix? I have firmware v 1.0.0.48 installed. And i do use readyshare for a laser printer. thank you
- Feb 01, 2016
I think I'll probably do this http://www.dd-wrt.com/wiki/index.php/Netgear_WNDR3800
But I'm looking at the AC1900 Nighthawk also
ElaineM
Jan 27, 2016NETGEAR Employee Retired
Hi rungel,
Using the latest firmware should correct any issues like this.
Do you have the latest firmware installed on your router?
Here's a link on how to upgrade the firmware.
In addition to this Avast vulnerability, kindly see this thread.
- rungelJan 27, 2016Tutor
Hi ElaineM,
I did have that version installed, but went ahead and flash it again. But Avast still tells me the same issue is there.
- mediatrekJan 27, 2016Virtuoso
Per Netgear's EOL (end of life) product policy, they will have long since stopped support for the WNDR3800 with anymore firmware updates; even if there are security holes in the firmware. Basically you have to go out and buy a newer model router. Netgear will not be fixing it. The end.
- adelacFeb 01, 2016Aspirant
I hope this is not the end...
I'm in the same position : firmware uptodate and NON-2015-0211 issue.
Please NetGear : consider working on a firmware update fixing this issue.
